suprdzlduty
ok guys just need a little clarification...is the return fuel from the hpfp and the return from the injectors, since they run together, once it goes through the cooler, is it filtered again? by the looks of it, it is not...i took the fuel bowl on the engine apart and it looks like it just gets recirculated without going through the filter again...i know a certain portion does return to the tank, but it appears that some of the return can and will go back to the pump.
