Joined the 700 club today, on stock nozzles! Dyno vid
Rubenk
KCMO
So I finally cracked the 700hp barrier today. On stock OE injectors and nozzles! Factory longblock aside from studs.
713hp 1479tq
Power mods:
No limit Intake
RCD 75/59 stock appearing turbos
4" SDP Downpipe
CAC pipe
Midwest Diesel tuning via H&S
Studded
Precision wastegate on spring only
Dragonfire HPFP
Fass 165 LPFP
52psi boost
70psi EBP
EGT never went over 1500
Rock solid 24,500psi ICP
Ran in 4th gear with TC locked from 1950 to 3950 RPM.
I knocked the exhaust off derete-pipe back at the track last time and just havent put it back on.
https://www.youtube.com/watch?v=moNuD3K98oo
Rubenk
KCMO
Just to add this Dyno can load the **** out of a truck, enough to completely kill it. I dyno'd on it a while back it the numbers were within 5hp of what track times were putting me at, so i'd call it very accurate.
bigrpowr
<How I Fly
Administrator
congrats dude ! i did 723 on stock pump/imjectors back in the day. that's a fun truck i'm sure !
Rubenk
KCMO
Yep! Theoretically stock HPFP should be able to do exactly this. My new reman pump just wouldnt hang though, and I didnt feel like going through warranty claim on pump after pump till I got a good one, so the dragonfire went in.
Stroker f-250
Brownwood Tx.
Holy smokes, I dynoed the other day and and got 615/1225 with 76/59 setup and airdog 165 with ******* 350 tune. I feel like I should be more than that, especially after seeing this.
Rubenk
KCMO
My previous dyno was with a reman pump, no fass, and no 59 and it did 644hp.
Rubenk
KCMO
Also, thanks everyone!
Props to Morgan on his tunes.
I ran Tyrant's as well, with no pilot injection and 6 degrees less timing it still pulled 689hp. It was more of a testing tune than anything.
bigrpowr
<How I Fly
Administrator
different dyno's and different days. i had high power's make 621 before , so take all dyno numbers with a grain of salt .
Rubenk
KCMO
Definitely this.
I do have alot of track times putting me at 640-650hp with that combo though.
Stroker f-250
Brownwood Tx.
Maybe I should try Morgan's tunes as well, I had matts but he pulled way to much fuel out of it.
And having high powers and making 621 would prolly make me very disappointed.
Hopefully it just the dyno.
jcain
6 or 5 ?
