Powerstroke214
Found one in sexual chocolate color and decided he had to have it.....
Tru, Gary Hoover can't resist sexual chocolate
How so ?
It's my understanding that the regen process on the 6.7 doesn't add fuel into oil as the 6.4 did
it's the exact same regen process, so...
Well that and the EGR system gums everything up just like every other EGR system on a diesel.
Meh. Thats debatable. The emissions system on the 6.7 is much more refined than its predecessor. While I agree it's not ideal and can be messy, it's hardly fatal anymore.
Sending your packages this week, Gerry![]()
Dustin, how does the egr lower combustion temps? Clearly my understanding of system is lacking somewhere.
But because of the aforementioned points, the only reason I'd delete a 6.7 is because I like loud noises and because I can't stand that tip(and filter backs are a waste)
the whole point of adding EGR is to add an inert gas to the combustion chamber which lowers combustion temperature, which lowers NOx.
CAT actually had a great idea on the 2007 truck engines by taking gas after the dpf and putting it into the intake system. CGI is what it was called. Clean gas induction that does the same job. Bad part about that is the amount of piping needed to make that happen just isnt realistic on a pick up, and hard to keep leak free.
Disagree with part of this, Its not exactly the same. Once you add in An SCR you have effectivily changed the entire process. Since NOX is no longer controlled as much by egr you are allowed to run a higher combustion temperature (which is why EGR is there To lower the combustion temp to lower NOx) THe higher temperatures allow for more ash and soot burn off in a natural "passive" regen state. This requires less fuel to be injected into the engine to do a regen.
The thing is I have yet to see a 6.7 oil sample come back with fuel dilution. We have a whole fleet of them here and the oil doesn't get changed untill the reminder on the dash says to. So even tho the theory is the same the actual result is little to no dillutionIt's the same in that it's injecting late fuel to get heat up enough to clean the soot.
It may not happen as often, but it happens.
If you had a 6.4 that constantly pulled a moderate size trailer constantly down the highway and a 6.7 that idled 8hrs a day, the 6.7 would put more fuel in the oil than the 6.4.
all things equal, yes the 6.4 will tend to get more fuel in the oil than the 6.7
but I'll split hairs on the statement that it's because of the regen process![]()
And let's not forget the moisture... Other than that it's by far a stellar idea.
I agree and dissagree at the same time. With the addition of SCR and urea egr usage is reduced by 80%, HINCE the reason the egr cooler is now smaller because there is less going into the engine. These engines have proven to go over 350k miles in bone stock form with very little issues.
People dislike what they dont understand. I know even for myself I thought oh great look at all this extra stuff they added. But then after hearing the reasons why I look back and say wtf were they thinking trying to use egr only to clean up NOx? That seams like a good way to dust an engine on its own.
