powerstroker66
Late 99' 7.3 engine from a Tennessee truck. Ran when pulled. Asking $1500 located in eastern pa 18947 call/text/PM me 2156221406
Most anyone on here is gonna want a compression test before they think about buying this
300 is pretty damn low on compression. Usually we consider an engine in poor condition if it has below 350 psi in any cylinder.
Pretty sure factory spec is 400 - 410 psi. Anything 350 or higher and within 10% is what is desired. Of course elevation is a factor also.
Cold or hot?
Holy hell... that means I put 50k-60k miles on my dually when we did a sorta warm compression test and the numbers where right around 300lbs across the board. If thats considered low. Then I had one of a kind... cuz it didnt have one issue starting or running. Blowby wasnt an issue either... just bending pushrods.
Could your timing be way off? Just curious. Off enough that you could have valves opening when they shouldn't be to bend pushrods and not get good compression numbers?
