6speedsd
Ok, my current truck is the first 5R I've owned. My previous powerstrokes have all been 6spds. So I'm not that "learned" on how this thing works. But I'm having an issue. I know technically its a 6 spd, with 4th and 5th being the same gear, one used when cold, the other when hot. Ok, here's the deal. How many forward shifts should I have? Start off from a stop, should I feel 4 shifts or 5? My issue is I have a terrible quick shift. Like this thing will shift 2-5 before I hit 40mph, no matter how hard I'm on the throttle. I get 5 forward shifts, so I have what, 2-5 then OD? Or is 5 actually OD? Truck did this with stock tuning, although not as bad as it does with any custom tune. The bigger the tune, the more exaggerated it is. Like is I run Eric's tow tune, it quick shifts 2-4, then holds 5 and OD shifts. Matt's SRL...oh hell. 2-5 are insanely fast, then OD and lock up are very shortly after. Both guys have tweaked their files for me with little improvement. The tweaks Eric did showed the most change, but it never corrected the issue, which tells me its not tune related. I ran stock programming today, and it shifts quick through 4, then holds 5 and OD like normal. Put it on tow haul, and it'll hold the 2-5 shifts longer no matter the programming, but not as long as it should. You can watch the tach when accelerating, and it almost doesn't change rpms with each shift. That's how fast it goes through the gears. I hope this makes sense, and I apologize for my terminology in explaining it as I'm not that familiar with these autos. Truck has never thrown a trans related code (checked with AE), never had a gear or the TQ slip. I know it's something electrical, but I don't know where to start. Has a new direct drive Solenoid installed for the past week with no change (had slow engagement into reverse). New fluid and filters as well. This is driving me friggen crazy though. Any ideas? Truck is a 2005 2wd dually.
