Light bar activation by up lifter, help.
fine69
Cranberry Twp,PA
I've been looking to do the same thing, do you mind posting some pics? Also, how did you mount the light bar? Did you fab something yourself, or did you buy a kit of some type?
NY_Mott
The Real "OC" NY
Not at all.
The light bar came with two small brackets and hardware.
I picket it up from ATP in last week's special.
But i found with the bumper support layout I would still need some kind of mounting.
Spent several hours laying out a couple ideas but ended up doing a Z bend and welding it to the bumper support.
Then used the supplied mounts to attach it to that.
First time welding In years with a buzz box, so be gentle lol.
And I measured like a million times to make sure it what centered and dis not stick out the bumper at all.
I feel I came out pretty well for a noob.
NY_Mott
The Real "OC" NY
Thanks guys.
The positioning of the light is fixed.
But
If I loosen the supplied mounts, the beam has vertical adjustability.
I set it level and took a quick ride last which seemed pretty good. Will give it a couple days and see how I feel.
Will also post a couple night shots later.
