Light switch???
CSIPSD
Bend, OR
Not getting any marker lights to the truck or trailer... Headlights work, brake and turn signals work..
Checked every fuse...
Switch maybe? I need to keep moving so I can make it back to Washington without running lights...
PsdPullerJr
Western PA
No markers front and rear? I lost my rear tails and it was a wire corroded off back at the bumper at one of the connectors that hook the truck to the bed.
CSIPSD
Bend, OR
Why would the headlights work but not the marker lights? Got to be the switch?
Do the marker lights run thru the gem module?
Dave
Thats a switch if its on both the truck and trailer. Unless the fuses are blown
Those light circuits are wired seperately coming out of the switch. I shorted out a switch once and it was doing exactly what you are describing. The question is, why did yours go as I had to probe wires to cause it.
To amswer the gem question. No I believe they go into the dr side kick panel and then to the lights on the chassis.
CSIPSD
Bend, OR
Picking up a new switch at Ford shortly... $190... FOOKing expensive test. Hope it works!
CSIPSD
Bend, OR
Where is the "park lamp relay"...
Arisley
Arlington, Texas
Found it:
http://www.ford-trucks.com/forums/796193-wiring-and-relay-for-4h.html
The transfer case clutch relay is located in a RPO relay block. This block is behind the dash on the passenger side, up high near the base of the windshield.
The transfer case shift relay module is also behind the dash up high, but more over in the center of the dash up high behind the radio area.
The GEM module is a fairly large box with three plugs going to it, and is mounted on the driver's side under the dash, close to the driver's side kick panel area.
__________________
