Power Strokes
94-97 Tech
Little issue.
[QUOTE="7.3psd97444, post: 23924, member: 269"] Turned out to be the wire connector. It was loose as can be. Took it off, inspected it, and put back on and it's tight now and no batt light flickering. Also the idler pulley, tensioner pulley, and the tensioner itself were all bad. Replaced all three of these parts. The tensioner was worn so bad that the pulley would rub the bolt head that bolts the whole tensioner on the motor. The new one is a new and improved part. It's Beefier and longer. But still fits the belt perfectly. It actually wraps the belt around the alternator pulley better which I like. Also put a new belt on. No more slippage, batt light blinking, or squeaks under the hood. Problem solved. Thanks. [/QUOTE]
B-Code VOP
Latest: Powerstroke Cowboy
Today at 9:15 AM
7.3 Aftermarket
Latest: Tiha
Today at 8:05 AM
7.3 Aftermarket
9
Latest: 99fordman18
Yesterday at 12:02 PM
Sunrise Ford Parts
Lower coil spring pad bolt
Latest: KBMKVIII
Tuesday at 7:14 AM
B codes vs hybrids
Latest: Charles
Monday at 9:54 PM
7.3 Aftermarket
cmann250
ncollins64
Power Strokes
94-97 Tech
Little issue.
