My current turbo specs are Garrett-Volvo Gt4594
68X94 Comp 88X82 1.19 housing and is a t-6 setup.
Reason for the compound is Im gear bound when sled pulling. I can't get it off the line and spooled in 3rd and run out of rpms half way up the track in 2nd. Also, wouldnt mind a little quicker spool on the street, but overall it does excellent as a DD.
This turbo has been good for 650hp+ on the dyno, and has always done very good sled pulling and towing.
My big ? is. Is this turbo to small to be a LP turbo? I wouldnt mind losing a little top end power to broaden out the power band. Do you guys have any suggestions for a turbo that might work with this setup and be a HP? Is it even possible using this setup? Please excuse my ignorance on this subject. This is something I have never tried or worked on before.
