Low compression 7.3
SoCalPSD
Riverside Ca
So its been about six months and im tired of looking at my truck sittin. Last time I touched it I found out I had 100 psi in cylinder 5. So is there any other things I can check or test to see if its something simple because I don't really have the coin to blow on the truck with a baby due in 4 months. I dont need the truck but if i can fix it and keep it id like to but if it needs a new motor Im gonna say screw it and unload the truck.
Fat fingered from the phone- Corey
Vozar
Murfreesboro,TN
Pull both rockers and put air into the cylinder, this can tell u if it is a bent valve or sealing issue. If u hear air coming back through the intake or out the exhaust u have a valve problem. If nothing,more than likely its compression if it will hold 100 psi, but this is something u can try.
matt
Derek@Vision Diesel
Canby, OR
I am interested in the truck and I also have a motor if you are interested in it.
I know your in So Cal but possible a cheap way to get it from Portland down to you, maybe a member here making the trip or something?
