tireman3
I recently did headstuds, new oil cooler, egr delete with the cab off (06 F250). After i got everything back together and cab back down, went to crank truck and had a loud banging from driver side. Pulled Valve cover off and rocker arm on #4 had broken(plastic clip failed). I installed new rocker arm and pushrod. Cranked up and no more banging but #4 injector was inop. Towed it to local Ford dealer and he ran test and suggusted we try an Injector, which made sense. After injector compression on #4 is at 18% i believe. Ford tech is suggesting maybe it was something in the head job that was done. Heads were checked and decked by a very good machine shop. Any suggestions or ideas of what to do from here?
