lowerd/leveled 6.4l truck pics
ingrahams
New Hampshire/Africa
5.4 coils, no block in the rear, 20X10 American Force Rebels with 305 420's
ingrahams
Thanks guys, the omly thing I need to do is trim the front bump stops down a bit, there is only maybe a 1/4 inch gab now so any good bumps can be a little rough but for normal driving it rides great. Now to try for 1000RWHP on fuel
blk350on20s
Perfect. Exactly what i bought! Mountain climbs march 23rd then its comin down till memorial
ingrahams
The ride is great, If you hit a serious bump you can tell that the bumpstops arent far away but it takes a pretty serious bump or hole to compress the stops all the way.
Strokin6.4
Level on 35s. 22x10 with a 1/2" spacer
OUTLAW_6.4
IN
I have an 09 f250 ex cab and did the #4800 and remove block. Def sits a little lowwer in the back. Prob going to add 1/2 to 1" block.
Kedstrokin
Moulton TX
For the guys that went from lift back to stock or stock with 1" tie. Did you regret going down? My truck has a 4.5 and 37s with 3.55 gears. I'm really considering goin to stock with a 1" tie and 33s. How do I add a pic? New to the form
