Laybourn74
Looking for more info on this turbo! Is anybody running this turbo?
Jame's will be soon, I think he'll be the first to be able to give you real life results. I know the stage 3 runs awesome
The real beauty of the Stage 4/3 turbo(s) is that there will be no "visual" difference between the two as they look identical to the casual observer. However the Stage 4 should be good for ~50 psi of boost. I think that'll be some airflow for ya.
I'm real happy with the 68, just looking for another option for sled pulling to keep up with the 6.4's. http://www.youtube.com/watch?v=mibno-bnH0o&feature=youtube_gdata_player
True. But I really wasn't tryin to get at that. I've always been under the impression that vgts were made to operate efficiently at 30-40 psi. Aren't you driving em to hard when u push them past the point?
seems to run pretty strong...what size injectors you got?
pressure ratio of a gt40 series turbine and compressor have a far different pressure ratio map compared to anything thats used with a gt37 turbine. The stage 3 and 4 will be far more efficient at 30-50 psi.
He gets a.lot more involved with the internals than your off the self powermax.
