main bolt sequence which one?
ghostriderblk
vt365 main bolt sequence says to start 1 inner the 2 inner then 3 outer opposite and then 4 outer
ford manual i have says 1 inner 2 same side outer then 3 inner 4 outer same side.
if this makes sense. sorry hard to explain in words.
i broke a main bolt torquing to 170ftlbs final using ford sequence im wondering if that has something to do with it. not sure. my torque wrench is calibrated correctly.
ghostriderblk
I found the bolts
3c3z-6345-aa
3c3z-6345-ba
I used internationals sequence
The bolts for were 3 bucks a piece at ford
