Map sensor no boost
Bori813
Sent from my SM-N910T using Tapatalk
Bori813
Still getting p0132b code the vgt go up to 85% and down to 15%
Mesa, AZ
That all looks normal, except the vgt percentage. Your turbo may be sticking. Does it change pitch when the vgt cycles?
bismic
IMO vanes are sticking or you have a bad/sticking VGT solenoid. Normally the VGT should not go to 15% or 85% when engine is running (except if you are tuned, then 85% at idle isn't unusual).
typical values:VGT % duty cycle
low idle 73%
high idle 43%
cruise 55%
light accel 67%
hard accel 38%
coast 57%
Bori813
Looks like it stuck on vgt cycle it changes pitch when it cycles but not like before it seems to be slower
Bori813
I Changed the turbo still getting p132b I'm going nuts
Mesa, AZ
Did you ever check the vgt actuator? Do this by pulling it out, depress it with your finger a little, and have someone command it. You should feel it kinda buzz.
bismic
After answering the question above, could you repost the turbo data? VGT, boost (MAP), MAF?
Also, make sure the MAF and the IAT2 sensor connectors are tightly plugged in and the connectors and the wiring is in good shape. Since the turbo was removed, you re-verified no intake or exhaust leaks?
Bori813
OK I check the vgt actuator getting 12 volts when the ignition is on and the plug is disconnected and when I reconnect the plug it gets 0 volts on the vgt actuator
Mesa, AZ
Soujds like a wiring issue. What were you using to check ground? You may need to load test the wires. Use a headlight bulb and if it lights up bright, its good, dim, there is high resistance.
Bori813
I have a volt meter work good
Mesa, AZ
Are you using the ground wire for the sensor, or are you going to chassis ground? Also, a volt meter will not be able to properly load test a circuit. You could ohm out a circuit with 1 or 2 strands of wire connected, and it will ohm good. But obviously, thatwill not carry current very good.
Bori813
I was looking at a video they were showing on YouTube about to check your turbo actuator and it seems like there's was closing all the way mine's is staying open a little bit but it's not closing all the way. Looking for a ride today had no power by got the boots up to 6 PSI with the throttle almost to the floor
Bori813
Thanks for everybody's response I found the problem it was a bad Turbo put a new turbo in running like a charm
What? Wait.. .You said you changed the turbo in post 46
DEEZUZ
NO PUKESTERS
NWI
Probably a Ford reman... Which are known to be junk out of the box.
Bori813
Yep it was a reman had me going crazy but order a brand new one sorry for the late response
Sent from my SM-G935T using Tapatalk
DEEZUZ
NO PUKESTERS
NWI
I just had a complete and running engine from Ford come back in 1k miles. Impeller shaft sheared and sent the exhaust turbine out the tail pipe but not before it made a hole in the down pipe
