groove
So, 3500km on new build (signature) I'm at idle and notice what sounds like a marble in a can. Sounds like its coming from the bell housing. Thinking the crank spacer that the machine shop removed and then re-mounted has shifted and cracked the flex plate or something of the sort...
Truck runs great, trans temp in the 160-175 range. Noticed a little vibration when in 5th and TC locked when I get on it. Smooth at cruise.
SO..trans is coming out to see whats up.
For those who have pulled the trans, did you separate the transfer case prior to dropping it or did you just yank the drive shafts, cross member and slide the whole show back?
Doing this in the drive way, no more $$$ for shop time.
Thanks all
Thanks all
