Mini Green Monster Build Suggestions
03mm
FL/MD
So I bought a 07 6.0 RCSB mosty just has cosmatic upgrades with a few engine mods. I plan (hope) to make it in to a lil 600+hp street truck. I am looking for some suggestions and comments on my parts list since i am still new to this.
Engine mods currently on truck: Airdog II, sctx3, innovation tunes, 03 turbo, 4inch turbo back exhaust, afe stage 2, FCDP Welded intake/egr delete, updated oil cooler and stc fitting
Plans: studs, gaskets, dd reg return kit, no limit piping, thumper 1 hpop
Not sure on injectors and turbo maybe 225/100s and 68mm powermax?
Would that be a good build?
Other plans: traction bars and new wheel/tire package.
Craig@MFI
I would do a set of 190/100s with a thumper 1 pump and a non vgt 64.5fmw be a fun little truck
Sent from my SAMSUNG-SM-N900A using Tapatalk
04 f350
I was thinking 190s at first. Why should I lose the airdog?
Because its a terrible fuel pump, bad design an everything. Believe me I know I've been thru 4 pumps in 2 years. Do yourself a favor and go with a fuel lab or A1000 setup.
JGman141
Ohio
:whs::badidea: to run an airdog 2, mine went out 4 times in one year and couldn't come close to fueling 205s
03mm
FL/MD
Craig could you pm me what I would be looking at price wise for that set up to also include studs and gaskets? @craig@MFI
Hmm maybe I need to look into changing that out I guess.
FaSSt9602
Gilbert, AZ
Or run a 6.7 pump...You will have the reliability of OEM, and be able to supply more than enough fuel for 190's...
Craig@MFI
Yes I would go with the stock 6.7 pump as well very good pump
