Modded H2e???
CSIPSD
Bend, OR
What exactly is modded on the modded H2e? I need to rebuild mine, and if the exhaust wheel is damaged I will need to replace it.
Is it just the compressor side that is modded?
Pretender
Yes. Depending on who's version your talking about. The standard is 62 or 64mm the modded is 66mm with a different cover. Most have 17cm housings some have 19cm housings
CSIPSD
Bend, OR
Thats why its in Beans vendor section... Its a Bean's modded H2e...
BDP Sales
Murfreesboro, TN
We install the larger (66mm) comp wheel, machine the comp housing for the larger wheel, and if it needs a rebuild we also rebuild it. If the turbine wheel, shaft, or center section are damaged beyond repair, it is an additional cost to repair the necessary parts.
CSIPSD
Bend, OR
I've loved mine...
I called Pius about rebuilding it, and while I love talking to him, he more or less told me to throw it in the trash...
I have nothing but good things to say about this turbo, its been tough as nails.
Can you guys shoot me a cost to rebuild it, I dont see any damage to the exhaust wheel as of now.
Thanks!
BDP Sales
Murfreesboro, TN
I've loved mine...
Thanks!
It really just depends on what it needs, and we would need to have the turbo in our hands to give you an accurate price assessment.
But, just to give you an idea, i had a customer send in an H2E this week that he has had on his truck since like 2001 or something like that. Anyways, when we received it the thrust had so much play it was wallering out the bore of the center cartridge and had made contact with the 2 retaining clips. His bill ended up being an extra $280 over the cost of the upgrade and simple rebuild kit.
CSIPSD
Bend, OR
Thanks for the info... I asked this to be moved so I would not muck up your area at all with my questions!
Here is a picture of the exhaust wheel before I cleaned it...
And after I cleaned it (all I have in my job trailer to clean is bleach hand wipes... Kind of a germaphobe...LOL)...
Looks like its just oil or something coaked on it... Once I removed the housing it is spinning free just fine, no play nothing.
Here is a shot inside the exhaust housing...
BDP Sales
Murfreesboro, TN
Are those grooves in the turbine housing in the metal from the wheel, or is it just coked up? The turbine wheel, after you cleaned it up, doesn't look bad at all from that one picture.
CSIPSD
Bend, OR
Its just all coked up. No grooves at all. I need to go get some brake clean today and clean everything up good.
Had owners on site today, so I had to play super, rather then truck mechanic... LOL
CSIPSD
Bend, OR
I did see it. If I was not running a shoe string budget I would get it.
Unless of course someone wants to trade a ZF5 conversion for a modded H2e... LOL
