Motor much louder after S364.5 SXE install
Baker42
New Mexico
Installed my T4 mount and 364sxe turbo this weekend. It lights a hundred or so RPM later but takes off pretty fast. I believe my injectors are stock but previous owner said they were upgraded. BS. Anyway the engine noise in the cab sounds like a old tractor. I mean wayy louder engine exhaust noise. I used 99.5-03 superduty plenums with Riff Raffs billet inserts. The holes on the 3" plenums had 2 extra holes that my heads were not tapped for. I just siliconed them over. I dont believe they are leaking. Truck sounds almost the same out side the cab, but inside there is vibration and more engine noise. Is this normal? Thanks in advance.
suprdzlduty
Prospect, Oh
you posted in the classifieds…should have posted in 7.3 section…sounds like you down pipe may need adjusted…probably rubbing the firewall
Baker42
New Mexico
Pulled downpipe and worked the firewall more. Much better. Maybe even quieter than the old Diamondeye downpipe. Thanks suprdzlduty
