MY 6.0 RACE TRUCK BUILD
IIVonnyII
Langley, BC , Canada
I second the BTS 4r100 , although , 5rs are started to get figured out. there are a few builders out there that can build a stout reliable 5r nowadays. one thing you should reconsider imho is your turbo choices. 66/88 isn't the best set up . you didn't mention if its a 66sxe? or box 66. big difference. I would throw that 66 away and get a 369sxe , feeding an sxe82 .88 is a little bit big of a jump . depends on what you plan on using the truck for. how streetable you want it etc. 69/82 sxe with 330/150 hybrids.. right around 900-1000 wheel. if you want to go crazy use the 472 sxe feeding the 88sxe.
you mentioned racing a lot with your old set up.. what were your times?
