My lowered 03 4x4!
Wojo
im not 100% i wanna be completely level. i want a small amout of rake to it.
BigTonka
Minneapolis, MN
Stock height front, 2" block in rear. 305/50R20 tires. Would've looked better with the back end dropped another inch or so...
awesome looking truck
91turbogsx
Gardner MA
How much space do you guys have between the front springs and the bumpstops? I wanna lower my truck and was thinking about the possibility of Excursion front springs. I'm not offended to hitting the bumpstop. LOL but I wanna know how much of a difference between stock Super Duty springs versus Excursion springs.
Wojo
as far as rubbing with the current setup i have none. none at all. turning radius is good. and right now im a good 3-4 inches off the bumpstops. i could go lower if i wanted but i dont think i will. the rear is going to get lowered and the running boards will be coming off. i can almost garuntee that the excursion springs would do the trick to get it lower.
Agjake11
Rosenberg TX
What's your offset and wheel width. I ordered my 20x10 -24mm with 305/55/20's and think i should clear but not 100% yet
Wojo
im not sure what my offset is. they only stick outside the factory flares about half an inch
Agjake11
Rosenberg TX
Just found your thread on psn. Rather than bump it I'd figure I'll ask here. Need some info on that front bumper. Looks sick
Wojo
i did it myself. just cut it out before i painted. an angle iron bracket bolts the the bumper mounting plates and the hellas bolt to it.
Wojo
heres an update. finally pulled the rear block. i defineatly like the look alot better. not sure if im going to pull the steps or not. the wife might bitch. not sure yet tho. i just need a tannuea cover now and i will be happy for a while
Countryboy07
N. Manchester, IN
When I pulled the block out of mine, I thought it looked like it sat too low in the rear which is why I put the 1" block back there. Your truck looks good though!
Wojo
mine sits half an inch taller in the rear. i contribute that to sagging front leafs
