my problems..
Ouch
Watertown,MN
Guys from psn know my broke down 7.3... today I noticed water dripping and possibly oil.. I went threw a puddle 15 miles and an hour earlier.. I would think it woulda been dry...
Oil drips hanging off the frame by the radiators on driver side.. don't know if its old or not anything to worry about yet or just keep an eye open.. what's a good degreaser so I can wash engine and watch for leaks..
ITUKMOR
Smyrna, TN
Sounds like your oil cooler took a chit bud. Clean it off good and I think you will see that is where the mix is coming from.
BMac
Nova Scotia, Canada
Tom S
The best product I have found for cleaning up oil and grease is called Oil Eater followed by hot water. I use a pump up garden sprayer to dispense it.
bluedge8
Champlin MN
Simple green also works, just don't use a pressure washer. And the oil cooler is just above your oil filter.
Ouch
Watertown,MN
where is that located, like general area... Ill go out with a flash light when I can and poke around..
bluedge8
Champlin MN
it goes from the front cover to the oil filter, it has both coolant and oil going through it and is known to leak.
Ouch
Watertown,MN
Sent you a PM.. from what i could see the cooler looked fine.. might have found the prob...
Ouch
Watertown,MN
possible.. has the blue rubber coupling connectors..
Went out to the truck noticed a tube not connected anymore.. miscommunition from me and the builder from previous problems.. didnt get tightened.. got it back togeather.. Boost gauge works again now too. Hope no damage was caused.
Ouch
Watertown,MN
Yea just searched, intercooler tube.. someday I'll learn something about this damn thing..
bluedge8
Champlin MN
man your going to love driving it today, you will have boost! sorry about all of your problems Corey.
TARM
Just not on anything made out of aluminum as it is cuastic to it. I love the stuff for anything else but this all the alum being used these days....
Ouch
Watertown,MN
is there anyparts I should not spray with the hose? Hopeing to wash it sometime this week.. a little busy..
Big Bore
9000ft in the CO Rockies
I did not know that, thank you, I just bought a gallon of simple green and was about to soak my entire engine compartment and undercarriage to remove the remnants of blowing a HPO hose at 90 passing a car.
Ouch
Watertown,MN
I could onnly imagine my next post after soaking the entire compartment with simple green...ha:doh: Thanks for posting that
