kersey1999
Ok guys are you ready for an update. Here is what I found, I removed both outer hubs, needless to say they were stuck and in bad shape. The passenger side front shaft was also worn, I believe it was where the dealership attempted to put it back together and did not get the clip on right, it was hanging in the hub grease. Needless to say after a new front shaft and two new hubs 4x4 is working to my liking! Now I have to try it out in the back yard to see if it works there. I tested everything out in the air, so tomorrow will stand the true test...Wish me luck!
