I have a 99 international 4700 with a 7.3L in it. I've cleaned the IPR and replaced the LPOP. The truck will start and run perfect cold but when up to temp. it shuts off. with the HPOP dead headed to a guage it only makes 150-200 P.S.I.. when cold the HPOP will make 4,000 P.S.I. so i'm assuming my HPOP is junk, If this sounds right to y'all could someone point me in the direction of where to get a new pump (stock replacement) cheap and relatively close bye? And the HPOP reservoir is full at all times as well.
I'm located in Murphy,N.C. which is the far west tip of N.C. thanks in advance for any and all help.
