ok so i have a 2008 and i did a single turbo setup on it as well as some other mods ill put a list for yall to get an idea of what i did.
MPD oil cooler delete plate
Mishimoto 25 row dual pass oil cooler
Remote mount screw on type filter housing
oil lines made from 2 wire hydraulic hose
S467.7 FMW from MTP 67.7/74/.91
Single turbo pedestal and piping from Midwest Diesel Auto
MPD Fuel bowl delete
Mishimoto intercooler
Gearhead tunes on H&S
FloPro piping
fass pump
motor was previously:
Studded
Hamilton springs/pushrods
egr delete
diamond eye 5" exhaust
6.0 manifolds
Rudy's hd up pipes
full billet trans and convertor
when i fired it i got a rough high idle (1100rpm) and the oil light came on so i killed it and checked the oil. added 2 quarts to compensate for the new lines and cooler. tried it again and the light was still on after clearing all codes.
then i out a manual guage on the delete plate and got no oil pressure.
it threw these codes:
p0193 Fuel Rail Pressure A circuit high input
p0101 MAF/VAF circuit range/performance
p0118 ect circuit high input
p0113 iat circuit high input
i didnt have a MAF sensor to put in it getting it from the ford house tomorrow. i moved the intake air temp and MGP sensors the driver side of the intake to clear the 5.5" inducer on the turbo and the No Limit intake. ill recheck tomorrow but im pretty sure i didnt cross any wires. the coolant temp sensor is plugged in but im still getiing the code which is weird cause engine was cold.
as far as the Fuel rail pressure problem im not sure where to start. i wasnt sure how to set up the regulator that i got from MPD but i didnt think it would cause a high rail problem and i could adjust it while idling.
so my biggest issues right now are the oil situation and the rail pressure. Any help would be greatly appreciated!
FloPro piping
fass pump
Studded
egr delete
6.0 manifolds
Rudy's hd up pipes
