JD3020
Little background on it. Engine is in my F450, it was originally a T444E out of a bus, been converted over to a truck, i think its somewhere in the 120-140k mile range. Last winter i pulled it out of a wrecked truck i had, re-sealed everything except the front cover and rear main seal, and stuck it in my 450. Went several months with little to no leak, had some seepage around the front cover but didn't really drip. After a couple months i had an HPOP line blow on me, and for whatever reason this thing started leaking oil badly shortly after that. I'd say it leaks about a quart every 500 miles, pretty steady leak.
Took a couple minutes today to take a look at it. What i can tell is the valley is dry, oil rail plugs are dry, turbo looks to be dry, pan doesn't seem to be leaking. The only places that have any real leaks are the back of the heads, coming from the valve covers. But they just seems damp, not an actual stream of oil that i can see. I wiped everything off and watched the oil, and its all coming down the inside of the bellhousing, and leaking out of the bottom holes on my ZF6, no oil is coming down the the pan.
So what in the hell is leaking? It has me stumped, only other thing i can think of is the rear main seal but i have a hard time believing its leaking with only 140k miles, and being an 00/01ish engine. Need to get it fixed though as its my work truck, and is a bitch with it leaking oil everywhere i go. Hell theres a trail of oil on the road from where i back in every night. :shrug:
