BFT
tadd had one of the trucks running the exhaust on the outside of the framerail
run a stack thenLOL
how much room do you think these trucks have if you were to cut out some of the firewall?
not sure i might be able to bend the pinch weld back a little for more clearance and oval the pipe a little bit to clear, i think i have a plan now on doing it whether it works or not is totally different LOL
im not going to do anything that drastic on this truck,well, if you have enough room from the firewall to the heater core, or whatever sits behind there, you could cut it out and make a piece of sheet metal that goes in the shape of the DP and have clearance.
that is if there is enough room.
dude...you have/had a procharger and the 1st single turbo on your 6.4LOL
I know but pretty much everything i have done is reversable
Nothing sicker than a turbo in the fender well...
