Need vendor help. Looking for aftermarket 7.3l CAC\intercooler pipes and plenums
Homesteader
I personally like the o-ring just because. But yes I know both will work,o-ring seems to be easier to work with if needed to. Just my opinion .
Arisley
Arlington, Texas
Most times I agree with the o-ring, with the plenums I think even if there was an o-ring, I would not feel comfortable unless I put some Grey Death in there.
CSIPSD
Bend, OR
I've hit mine with 55# boost now for 12k... Mind you this is not every day, but I will hit 40psi about every trip down the hwy.
NO issues. I will never go back to glue.
CSIPSD
Bend, OR
With an H2e?
Yes...
http://www.youtube.com/watch?v=HzkMbcWenFQ
INFRNL
Colorado
I can peg my 60 lb gauge with an H2E also. Course, Tony has never been accused of being easy on the fuel.
Maybe you guys have bigger turbos than I do. I do not have an H2e, I have a Pius LASB from Jake@Irate. Its a s300 framed charger whith whatever mods Pius did and I believe it uses the QSSB wheel. I think its like 76.2/68 wheel.
Supposed to be pushing around 50psi but optimal to keep it at 45 or under from what I'm told. Maybe I need a bigger turbo so I can keep up with with you guysLOL
That's some nice boost though, that's got to make a big difference over what I have
Austin, Tx
Just because they are making that kind of boost doesn't mean too much in terms of power. You can make over 500hp with 35-40psi boost pretty easily..
dirk0
boost=$hit breaks.
I'm trying to reduce as much restriction as possible.
dirk0
I can hit that high of boost as well. Got the pics and vids of broken crap to show for it.
CSIPSD
Bend, OR
Boost does not equal HP... Was not showning that to prove anything other then the O-ring works great! Much better design and function.
Snowman269
DL, MN
Agreed...except for 2 things...
1) the resrictive metal at the bottom of the inlet..
2) the mass around the intake to allow for a lttle more of the sealant
we corrected both "flaws"...if we didn't make'em we would push Clay's
I know it's picky but we took it that much further
Nice, I'll remember that for my next ones.
dirk0
Parts are rolling in. Thanks!
Southmike
..look great but...
also looks like the restrictive metal is still there in that pic
what are you doing for pipe work.
thuglike
Linden, NJ
our piece has a concave bevel instead of being straight across to minimize air turbulance...........like I said.... "picky" :D
It looks like a restictive piece in the photo but it's not.
