New 6.0 Single turbo setups
06f250powerstroke
ontario, canada
Have you tested back pressure with that setup? I know i have smaller nozzles on my 190's than you do, but i wonder how your new charger setup would do on my truck with 75% nozzles?
I would only assume that BP would be less with a T4 housing, I think your nozzles and this set up would be fine, maybe just less top end
06-6.0 stoker
So all of you agree on a 190/100 injector setup the 66/74 turbo with manifolds/pipes is a good street daily driver?
Pizza pig
MD
If youre looking for a do one do all setup, 190/75's and the mpd 64/68/83 kit will do just that.
Extended Power
Could I get a quote for a set of up pipes built with the T4 flange please?
Hoping you make them available without the exhaust manifolds...
Mike B
carmel ny
It's real tight I put a another 90 on it and it worked out. Don't know if putting another fitting in is bad or not. But that is a real nice kit and I'm running mpd 190/100's and their single kit 66/91 trucks runs real strong .
FX4 F2-Fifty
East Houston/San Marcos
Anyone have pics of their turbo and how their drain line is run on this kit?
Ummm... I posted a link to a thread that has a picture of it and to buy a 10 dollar part that makes things so convenient. Here it is again.
http://powerstrokearmy.com/forums/showthread.php?t=19845
Just look at the gates hose I used. Its a 5/8 pre bent hose. I tried installing the supplied one, it kinked and was a pain. Got the hose, cut it down to fit. 5 minutes and a clean, kink free oil drain.
Sent from my DROID BIONIC using Tapatalk 2
06-6.0 stoker
Ya sorry I missed that the first time. I'm on my phone.
Got the same part. Made it work. Thanks for the help. Truck runs great
06-6.0 stoker
Anybody have any problem with their exhaust sealing up? After the first drive I have soot allover the intake manifold by the turbo. Took the downpipe off at both ends got a new clamp, attached to turbo then on the other end cleaned up.
Took it for another drive, soot again. And I can smell exhaust when idling
Craig@MFI
which part are you having a issue with? never had anyone have a problem with exhaust leaks
