Blowby
- Joined
- May 22, 2011
- Messages
- 1,531
- Reaction score
- 0
Also inspect the pipes and manifold where the boots connect. They can crush and deform if tightened too much and will not seal properly.
there is supposed to be a o-ring in that joint there.......
:whs:
Although it sounds like you found your issue.
For everybody else, a word of caution, when using a leak detector, be careful. 15 lbs is plenty to find a leak. Back when I first started in this game, a moderator on the forum of the time (KLHanson and TDS), pressurized to higher pressure. While sticking his head in the engine compartment close to the boots trying to locate the leak, a boot blew off. When a boot blows off, it is loud, real loud. He broke an eardrum and spent a few days and a lot of bucks with his local doctor. I don't know if he ever fully recovered. Remember, you can hear with one ear, just like you can see with one eye, it's just not as much fun.
Very good advice here. I'm a fella that pressure tests to "higher pressures" and have found leaks at "higher pressures" that didn't show up at lower ones. During this one fine day....I was just smart enough to wear muffs and safety glasses, but just dumb enough to forget my football helmet and body armor. During one of my first "high pressure" leak testing sessions, my leak tester became a fast moving airborne projectile, but I was lucky enough to be on the correct side of the engine compartment when it came loose. That only cost me 1% of personal pride, new shorts, and about $30 to build another leak tester.
