Timmy
Brand new Kennys dd clutch for the zf6 and new throwout bearing, has a insane noise coming coming from I believe the throwout bearing when clutch pedal is completely depressed. Truck won't go in gear until the pedal is on the cloor, but clutch releases at the top of the pedal (like a inch from the top). What did I do wrong? Fork wasn't bent or cracked when I put the new throwout bearing in. This is the 2nd day driving it on the new setup, so there are a few kinks to work out, but this is the major issue. I've done clutches before but have never had this issue. Any ideas before I drop the trans? Thanks fellas
