Wild Phil,I bought my 05 F-350 in September of 2012, she had 140,xxx miles. I put 10k on it in the first three months, driving back and forth to work in North Dakota. In October '12, the EGR cooler blew. Did an EGR Delete and added a SCT tuner. Had to replace the generator and a battery in '13. Last month had an issue with antifreeze blowing out of my degas bottle. Thought it was the heads. Turned out to be a bad oil cooler and truck was overheating. So, she is actually in the shop right now getting a new cooler. Figured this would be the perfect time to do some mod upgrades and preventative add-ons so; studding the heads, replacing the stock injectors with 155/30, adding Sinister Regulated Return, Oil & Coolant filter, 4 inch exhaust and a Max Tow EGT gauge. Next step will be a new lift pump, 66mm turbo and a billet converter. Thinking about the T4 kit with a S362 FMW...:ford::ford:
