New from OH - Help with Absolutes Delta Kit
plallen93
Ordered a Delta Kit from Absolute. However no instructions came with it and I can't get anyone to respond from Absolute. I tried calling and email. Would really like to put this thing on. Anybody have a link or suggestion to offer. Thanks
"I'm smiling...this should scare you."
plallen93
Anyone? It would be greatly appreciated.
05wh250
hendersonville, nc
The pictures in the beginning of the delta line kit in his vendor section pretty much show where it goes.
What exactly are you having problems with?
plallen93
Thanks for replying. Well I have a coolant filter t-ed into one of my heater core lines. Was wondering where I should tie the t from the Delta kit into. Also it came witih, what i presume is a block off plate for the egr cooler. I have an egr delete already. So do i just stash that part or is it still used and how?
05wh250
hendersonville, nc
The delta line should tee into the heater core line under the degas bottle. As for the block off plate, if you have one that already stops the flow of water through the intake manifold, yes just throw it in your parts bin.
plallen93
Simple as that huh? OK great. Thank you very much. I appreciate you helping me out.
plallen93
Just learned that Steve is busting his a$$ to get all this stuff out to us. Was not aware how busy the man is so disregard the comments about emailing and calling. He contacted me and set me straight on the install as well. Great product. Great shipping time. Cant wait to put it on. Thanks Steve! Sorry if I was a pest.
EODWayne
I am also looking for install help with the Delta line and manifold kit. Where did Steve point you to for the install instructions?
Thanks!
Heritage60
Purchased and installed Delta kit...I had NO change in my Delta...hose could be longer and instructions could be provided. I use these forums as others do to make decisions on purchases as well as hearing from others on ideas and suggestions.
strokin6L
Springville NY
I didn't use the line/hose Steve supply's with his delta kit...I made my own. I have it going to the aluminum coolant tank
gman2160
Sorry to resurrect a 1.5yr old thread ;-)
What happened to all (ANY) of the discussion about the "Delta Line" kits? You'd think that if this works as well as it was touted that it'd be a primary method of dealing with temp deltas.
because it doesnt work well.
gman2160
Thanks, that's kinda what I figured. Funny how a couple of years ago folks were talking about this taking them from 15-20 deg deltas to 2 degree deltas, then suddenly...crickets.
ODAWG714
Orange*County, CA
i can see a delta kit working or a nessesity when running a egr ******d manifold. other then that its pointless imo
