New headlight adjustment
CAT97
Fort Bragg, Ca
Just installed new headlight and turnlight kit from Paul.
I would like to raise the beam some so my question is do I need to take off
the clip that holds the headlight to the bezel then turn the small shaft or just
turn the small shaft?
cw96stroker
Central, Texas
Should just beable to turn the shaft to adjust man. Try it a lil and see and if it looks like somethng is getting in a bind, then undo the clip, not real sure what thissetup is like though.. but should be a simple task.
Pstroke96
Connecticut
You just have.to turn the shaft. For left ti right adjustment you have to remove the bezel. The best way would have to use a flat surface like a garage door and mark where the stock ones were with a pencil or something removable. Then after you put the new ones in line them up with the same marks
