New oil/coolant bypass installed
Pavestone87
Hey guys new to the forum. I recently installed my oil/coolant bypass that I put together and it turned out great. I used summit an fittings and bulletproof diesels cap set. I fabbed up a bracket for coolant bypass and just used the sinister kit and left that where it was. Let me know what you guys think....
mikah215
How much did you put into the oil set up? Maybe a parts list
03 f250 6.0 Sct with innovative tunes 5in exhaust coolant filter blue spring 190/30 bulletproof ficm&water pump aluminum rad Arp studs 8in lift 20x14 on 37s
Pavestone87
Bulletproof caps $227.00
Summit racing fittings and hoses $100
1- 1/8 npt to 4 an 90 degree swivel
4- 4 an hose ends
2- 1/8 npt to 4 an 45 degree
10ft- 4 an ss braided line " only need like 6ft though"
Amsoil filter base and filter $50.00
I could have done it cheaper with hydraulic fittings but I liked the red blue scheme.. I actually have 90 degree hydraulic fitting on there that I got from mcmastercarr for $5.00 and they are really nice. They are running to the coolant filter head
Pavestone87
Here is some more close ups of bypass its a 2006 6.0 by the way with 149,000 it was fairly simple. I'm pretty picky on things. It probably took me about 2 hrs to install. Metal bracket came from Home Depot and I cut it down and angled it so when I'm in there working on it I don't get anymore injuries.
Pavestone87
Coolant bypass running to tee in degas bottle through filter then to heater core hose
Pavestone87
Tee at degas bottle and fuel filter housing with pressure gauge
black'n'blue
Bad a$$ nice job. Would like to see what you pull out of the oil filter. How many miles before changing bypass oil filter?
Pavestone87
Also if you guys order the filter head and filter from amsoil its like $90 bucks. But if you pay the $10 membership fee its only $52 for both they give really good discounts for memberships.
