New TrueFlow Intake Elbow now available for your 6.0
SmedingDiesel
Smeding Diesel High Flow Intake Elbow for the 2005-07 Ford 6.0 Powerstoke Diesel.
Engineered for efficient airflow giving you the performance gains you desire. Although there are several competitors offering look alike's at higher prices, Smeding Diesel's quality and performance surpasses many of the competition. Manufactured with high grade 6061 aluminum with smooth True Arc Mandrel bends to ensure your boost flows at maximum velocity. Fully tig welded to ensure the rigidity of the Smeding Diesel guarantee. The Elbow has three 1/8" NPT fittings for boost, nitrous, or other components.
This performance product is compatible with all your factory components. It does have the bung holes that allow easy use of an external boost gauge, nitrous or other products. This product is great for all driving scenarios from towing to competition use, it will allow for quicker turbo spool and increased flow throughout the rpm band.
Specs:
Smooth true Arc Mandrel Bent
Large 3" Inlet & Outlet
High Grade 6061 Aluminum
Two 1/8" NPT pipe fittings
Easy to Install
Uses stock hardware
Also Includes:
Gasket
Two 1/8" NPT Pipe Plugs
Only $79 for Powerstroke Army Members! Use Promo Code: THEARMY on checkout.
http://www.smedingdiesel.com/product-p/ie60.htm
