Nitto 420s towing
RSK
Connecticut
I've hauled 10k plenty of times make sure they are aired up as much as possible in the rear. No issues though.
JrStroker
Ahead of the competition
I've towed the camper multiple times with them. 25'ish fully loaded older style camper. I don't know the weight but it's pretty heavy for what it is. Ran 40-45lb in the tires. Towed perfect.
04cr450
harford county, maryland
^that definitely is not safe to tow that much weight with those tires... they are not even rated to hold the weight of our trucks let alone towing something
7.3psd97444
Indiana
I've had 1500 pounds in the rearmost of my bed with no issues. That's not much tho. Tires didn't look like they squatted at all when the weight was added. 30psi in tires.
JrStroker
I thought it was safe. They have a load rating of 120. That's 3169lbs. But they also say Max load 3086lbs @ 50psi. So yea, they aren't the perfect match to the trucks specs for hauling/pulling but that doesn't mean they can't be used for such. After all they are Light Truck tires.
