mcdaniel1991
Could the regulator keep the oil from filling the filter bowl?
doesnt lpop have to fill hpo resevoir first so if there is a big leak in hpop circuit you will never fill the filter housing do to that is after the oil cooler?
The regulator bypasses the oil back to the inlet side once oil
Pressure exceeds 75 psi. The plunger could be stuck. You could remove it and the pump
Cover to inspect it.
