suprdzlduty
need some help guys, I have 07 that I did a delete, cooler, and high pressure pump and ipr on, when cranking it will only build 320 to 325 of hpo. I have plenty of low pressure oil. I have pressure tested the system and found a few very small leaks...relace the standpipes and rail plugs, now I cannot hear anything. no leaks. that at about 120 psi of shop air. do i need to test the system at a higher pressure?? in the past that has been more than enough air to show the leak. On the scanner desired icp is 1500 or so. Is there something im missing??
