littleredstroker
Swapped in single shots and a ts chip all at once. Cranks but won't start. When I plug in superchip to read codes it says No response. Any ideas
That the motor and the key are talkingYour wait to start light should come on and go off once the glowplugs have cycled.
And you do realize with an injector swap its not just gonna start up like normal. The best way Ive figured out is crank it for 10 seconds, let it sit for 10 minutes. Go back crank again for 10-15 seconds and again let it sit for 10 min. Go back and crank for the 3rd time sometimes it will take 30 seconds or more to fire but it should fire off faster then that.
You have an 03 so the tach wont move, but by cranking long enough it should build oil pressure.
And yes you can take the chip out and it will start and run and drive. Just it will run rough. If you happen to start it without the chip let it run for a few minutes at least before you shut it off. Then re-install your chip, make sure its cleaned properly(As if its not the WTS light will stay on) If you have installed it into the silicone you will have to clean the chip out as well.
