No start.
8inchstroker
AZ
Ran out of fuel....i know i know...anyways now won't start.has half tank, pulled line off pump in framerail and NO FUEL coming out. What next? Pump sounds like its working?
Sent from my LGLS991 using Tapatalk
8inchstroker
AZ
Been fkn with it for couple hrs...filled fuel bowl many of times i dont know how else to prime it
Arisley
Arlington, Texas
You gotta prime the pump
No you don't.
Add more fuel to it. Pull the line off the fuel pump going to the tank, if you get no fuel, remove the fuel cap and hit it with compressed air. Something is clogging it.
If the compressed air thing works, that is a temp fix. You need to pull the tank and do the hutch and Harpoon mods.
All you should have to do is add fuel, cycle the key a time or two and bust it off. It will run crappy for a bit with air in the lines, but it should clear up pretty quick.
