481986 05E16 7 .7 GENE STEFFY FORD, LLC 4342 22-FEB-06 * * * 31492401
Customer Comments PERFORM RECALL 05E16, PERFORMANCE ENHANCEMENT
Tech Comments REPROGRAM PCM
Details 7731564 S07 42 1.8 GENE STEFFY FORD, LLC 49279 14-JAN-09 5C3Z 9C968 CA 33264202
Customer Comments VEHICLE DID NOT WANT TO START LAST WEEK, HAD TO LET SIT FOR HALF A HOUR AND THEN IT WOULD RESTART
Tech Comments TEST EEC SYSTEM CODE P2290 & P2291. PERFORM PIN POINT TESTS. PERFORM IPR TEST. REMOVE AND REPLACE INJECTION PRESSURE REGULATOR. CLEAR CODES AND RETEST OK.
Details 7751741 S07 42 3.1 GENE STEFFY FORD, LLC 49279 14-JAN-09 4C3Z 9E527 BRM 33264203
Customer Comments CHECK ENGINE LIGHT ON.
Tech Comments PERFORMED EEC SYSTEM TEST, PINPOINT TESTS, DIESEL DIAGNOSTICS, INJECTOR BUZZ TEST, POWER BALANCE, MISS ON #8 CYLINDER. REMOVE VALVE COVER AND TEST, REPLACED #8 INJECTOR. CLEAR CODES AND RETEST. PASSES.
Details 7878175 S07 43 3.4 GENE STEFFY FORD, LLC 49893 10-FEB-09 4C3Z 9E527 BRM 33304801
Customer Comments AT TIMES VEHICLE LOSES POWER, WILL ONLY GET UP TO 40MPH, WILL COME OUT OF IT EVENTUALLY ADVISE
Tech Comments TEST EEC SYSTEM FOR CODES P0266, P2291. CHECK BOOST, TEST EGR SYSTEM OK. CHECK OASIS, MONITOR PIDS TEST VGT OPERATION OK. TEST DRIVE AND PERFORM POWER BALANCE TEST #2 MISS. PERFORM RELATIVE
Details 8689942 E91 51 3.1 HANSON FORD 59280 20-OCT-09 4C3Z 9E527 BRM 69133601
Customer Comments ENGINE MISSES AND BLOWS WHITE SMOKE OUT THE EXHAUST/
Tech Comments EEC TEST,PINPOINT TEST,INJECTOR BUZZ TEST, POWER BALANCE, MISS ON #8 CYL, REPLACED #8 INJECTOR, CLEARED CODES. PASSED
