Obd2 splitter
weazel
Elkview WV
Has anyone ever used an obd2 splitter? I was thinking of using one so I could run more than one digital gauge setups, I have my livewire and I may have modified my dash to make it fit, and I want something with a little better options for things to monitor
Sent from in a ditch up side down and on fire with the wheels still spinning
weazel
Elkview WV
I was think edge insight cts, or a scangauge
Zmann
they typically conflict each other since they are both reading sending pid request
you can try it because the cable is cheap
weazel
Elkview WV
Yeah the cable is cheap, but the second monitor is not
Zmann
if you don't have the second monitor I wouldn't try it
I use it for My Insight and either x3 or A/E and one will always overide the other
weazel
Elkview WV
Yeah I'm just gonna use gauges, add an EOT, fuel pressure, another pyro, and some other ones
Zmann
I use a cts and have a standalone digital EGT and Fuel PSI
weazel
Elkview WV
That would be awesome, I use the livewire for EGT, volts, injection timing, trans temp, and coolant temp, I just want to monitor a few more things, I am a gauge nerd, I want to know everything that is going on
weazel
Elkview WV
Yeah looks like I'll add more gauges, many more
gman1
Michigan
My OBD splitter works fine 99% of the time. If one of the Dash Daqs act up I just restart it and all is good.
