Power Strokes
94-97 Tech
Obs Ford rear door issues
[QUOTE="Garbage_Mechanic, post: 1472055, member: 1610"] For taper headed screws such as those that hold the door latch to the door I have found it is not something penatrating oil can help. It is the taper screw head locked ked into the taper. I like to use a flat ended punch and a pretty good sized hammer. Don't want to damage the screw head, but give it a whack like you were trying to drive that screw right through the door. If you have and old school hammer driven impact scredriver use that. If not, use a scrwdriver that fits properly. Get it locked in and apply as much torque as you can, then hit the end of the screwwdriver handle with a good size hammer. It workes like the old impactool . I've never failed to get out a screw this way. Used it on the door latch screws just a few days ago. [/QUOTE]
C
Latest: Cazador
Today at 1:46 AM
Sunrise Ford Parts
Lower coil spring pad bolt
Latest: KBMKVIII
Yesterday at 7:14 AM
Latest: 6.0 Tech
Yesterday at 12:34 AM
7.3 Aftermarket
B codes vs hybrids
Latest: Charles
Monday at 9:54 PM
7.3 Aftermarket
B-Code VOP
Latest: Charles
Monday at 9:29 PM
7.3 Aftermarket
Raider4044
ToMang07
Power Strokes
94-97 Tech
