Pstrke96
So I won the retard award today. While repairing the running boards on my 96 cclb Dually. I d rilled into the lower fuel line on the drivers side. There are 2 lines attached together running parallel from the front to the rear of the truck. It started raining so I quit while I was ahead, the truck still seems to run fine on the front tank. I don't use the rear due to a leak, with any luck I nicked the line I do not use? Any help and or a schematic would be most appreciated. Also the lines appear to be 1/4 or 5/16 thanks guys!
