OBS Regular cab PIC THREAD
Chrisf97305
Salem Or
Here is 1 of mine right after the new trubo install.
Oregon
How come I have never seen this truck? And you are in my area? Bad a$$ truck.
John at EIS has talked to me about your truck before but told him I have never seen it.
mwalsh9152
Wakefield, Ma.
That's not a powerstroke is it?
I do believe it has one swapped in AND 05+ axles FTW!
yes does.
That's gotta be fast its kinda lile regular cab short bed.
Its not bad, I put 3:73 axles under it so its not too quick around town.
Hell it's ten inches shorter than a regular cab short bed if I'm thinking right. Atleast I think that's wheelbase wise
its definitely pretty short. My rear driveshaft is under 24" long
tocker5691
shippensburg, pa
profile.php
http://www.facebook.com/media/set/?set=a.10150426845600162.637682.646305161&type=1#!/photo.php?fbid=10150840384555162&set=a.10150426845600162.637682.646305161&type=3&theater
Chrisf97305
Salem Or
I don't know how you missed it. I drive it all over the Salem area and up and down I 5. PM me is you want to stop by.
Chrisf97305
Salem Or
13 gauges?
I added 2 more with the twin turbos. 16 gauges, 1 gauge is a clock, and a DP turn selector gauge.
If you were wandering.
boost
exhaust temp
trans temp, temp going to the oil cooler
2 boost gauges as turbo drive pressure
vacuum
water temp
oil temp
engine oil pressure
HPOP gauge
trans line pressure
trans oil cooler pressure
trans pan oil temp
HPOP oil reservoir pressure
clock
DP Tunner selector gauge
