BigStack04
- Joined
- Mar 21, 2015
- Messages
- 19
- Reaction score
- 0
Well here is a bit of the back story. It's a long one but thought it would help more to explain the whole situation leading up to the problem.
About a month ago was I was driving my friend home from a bonfire. Going along the highway at about 60 or so glanced down at my stereo and the front passenger side tire drifted into the loose gravel(about a foot of gravel between the pavement and the 9ft ditch). Bald tires had no traction so I couldn't correct it in time. Went into the ditch pretty hard I was knocked out momentarily and my friend she was hurting pretty bad from the seat belt. Had a friend rush her to the hospital.
The ditch was so steep the truck was almost over on it's side. After the police left and it was pulled out by a wrecker I would say it was on its side for maybe 3 hours.
Next day went to get it from the town tow yard and to my surprise she only had a scrape on the front fender. Fired right up and was able to drive about a block before I came to a stop sign and it wouldn't move tow/haul light started flashing and finally feathered the throttle just enough to get it onto the highway and park it at my family's property. There it sat until last week I went to work on it.
Checked the tranny fluid and it took about 7 quarts to register on the dipstick. Tried to drive it again and it went about a mile this time before i had to stop at an intersection and the problem continued. Got it back home checked the fluid again and added more seemed to be getting better though. Now after repeating that a few times until fluid was at full hot level i hooked up my scan tools to get all the codes that pertained to the transmission. After clearing and then driving for a min I rescanned it and only got p0730.
Reverse works fine. Every other gear works fine once I get going. Starting from a dead stop seems to be the only problem. Starting with tow/haul engaged it drives perfect.
Sent from my SM-G920V using Tapatalk
