Power Strokes
6.7 Tech
Oil flow valve?
[QUOTE="Nic, post: 1514528, member: 5508"] Hope I'm not beating a dead horse as I haven't been on here in a while. I recently had oil temp of 225ish while towing around 6k with my 2012 and the truck cut the power in half from the temp threshold from what I was told. I've heard that the problem is a faulty oil valve in the pan restricting flow, and I've seen where someone had a dislodged freeze plug that was restricting flow in the upper pan. Has anyone had a surefire cause and/or cure to this? [/QUOTE]
C
Latest: Cazador
Today at 1:46 AM
Sunrise Ford Parts
Lower coil spring pad bolt
Latest: KBMKVIII
Yesterday at 7:14 AM
Latest: 6.0 Tech
Yesterday at 12:34 AM
7.3 Aftermarket
B codes vs hybrids
Latest: Charles
Monday at 9:54 PM
7.3 Aftermarket
B-Code VOP
Latest: Charles
Monday at 9:29 PM
7.3 Aftermarket
ToMang07
tangoparson
Power Strokes
6.7 Tech
Oil flow valve?
