DoubleL
Boy I really need help! Been driving my race truck around trying to make sure its ready for race season. Once I really started flogging it, with boosted launches and holding it out for 1/4 mile is when troubles start;
It sprayed coolant out the degas bottle, and then later on when looking in degas bottle I notice oil film on top of antifreeze. I hope oil cooler but I just put this motor in this winter and changed oil cooler o-rings at that time. This morning I noticed a small oil leak behind fluid damper pulley and was lucky enough to find a couple bolts loose on that ?crank cover?. Tightened those and oil leak went away and hoped that was problem so went for another test drive.
On this last test drive, once I got hood open I see it sprayed out antifreeze again and blew dipstick out and oiled down that area!!
What should I look at first? I did that headgasket leak test where you see if the blue liquid changes color and it passed. Truck runs good, and I've been driving it around quite a bit, but this last couple days were the first hard tests up to around 50psi boost. So my opinion is it only blows antifreeze out over 40+psi boost pressures.
Any ideas as other than tearing into a compression test I'm not sure what else to do.
