Oil leak problem
Powerstroker7.3
waxhaw NC
I started to notice my truck dripping fluid and it turns out it is motor oil. It looks like it is coming from the front of the motor about half way down on the left side if you are facing the front of the truck. Could anybody tell me some possible places where it could be leaking
Sent from my iPhone using Tapatalk - now Free
Justin@DP-Tuner
If it is on the front of the motor where you are describing, I would check the oil rail plug first.
Justin@DP-Tuner
Have you tried cleaning all of it off and then watching for where it is coming from? Sometimes that is the easiest way.
CGMKCM
Randolph County, NC
Check the V of the engine and see if oil is pooling in the various recesses. In my case the rear cover of the HPOP is leaking and slowly fills the recesses and then will spill out down the back of the engine. I also had the HPOP discharge fitting start leaking with the same symptoms.
